Kuidas Posted December 12, 2010 Posted December 12, 2010 Hello. I'm having problems with osd epg with the new version of DVBViewer. When I open epg and push green or yellow button nothing happens? With earlier versions the green button showed whats going on in all channels at that time, but now it does nothing? support.zip Quote
Kuidas Posted January 4, 2011 Author Posted January 4, 2011 Am I the only one with this problem? Is it my system or is this a bug in the software? Quote
Kuidas Posted February 4, 2011 Author Posted February 4, 2011 With version 4.6.0.1 the same problem, nothing happens with the green button. Quote
Tjod Posted February 4, 2011 Posted February 4, 2011 No problem here. On my system everything work as expectant. osd-green > what's now (EPG) > osd-green (second time) > program (EPG) [on you screen shot] Quote
