Maurizion Posted December 19, 2010 Posted December 19, 2010 (edited) When using channel editor i cannot add some channels to favourite list but some others yes and i don't undestand why . Seems that channels with multi audio tracks are ok and other with single track not , most of the time but not always. I use 4.5 dbviewer pro release. Thanks for helping. Maurizio Edited December 19, 2010 by Maurizion Quote
Tjod Posted December 19, 2010 Posted December 19, 2010 Each channel can only be once in the favourite list. Most likely the channels which you can't add are already in the favourite list. Quote
Maurizion Posted December 19, 2010 Author Posted December 19, 2010 Each channel can only be once in the favourite list. Most likely the channels which you can't add are already in the favourite list. Ok you are right , thank you very much for your help . May be could be an inmprovement to next release to add more than one time the same channel in different favourite folders because it coul be useful in some cases , for instance and HD folder and a movie folder both with the same channel. Best regards, Maurizio Quote
