m4a music, epg and record
xtonys
Hi
I really like DVBViewer over MC7 in many ways. It is very modular and customisable...
There are still some things I am not sure about yet...
Is there a way / plugin to play m4a or aac files I download from iTunes?
Is there a plugin to view the music files as coverflow, tiles view, etc?
Is there a plugin to pull-in related coverart and metadata also?
Is there a way to provide OSD option to burn an audio or MP3 CD from selected audio files/playlist?
When I look at OSD EPG timeline (using concinnity-3d skin), some favourites disappear and some program text is duplicated.
- perhaps I can edit a file somewhere to fix this?
When I record a show without pre-planning, it doesnt stop recording at the end of the current show.
Is there something I can select to make it do this?
- Is there a plugin to allow me to series-link programs? I only see Mon-Sun tick options at moment.
Is there a way to see more than 7-8 days of EPG data for Freesat HD and Freeview channels?
I am trying openEPG at moment.
When I look at the OSD EPG timeline, I see record icons continue past the show I plan to record. I cant change channels (on the same tuner card) until I go into Timer and delete the offending item. Pressing record button, then stop doesnt make a difference (timeshift is set to switch channels without a prompt).
Deselecting record and timeshift in the grey pop-up window doesnt make a difference either.
Thanks for help anyone can provide with the above questions...
Cant wait to get things fully up and running!
