XEPG import to RS error
Hi all,
Having big difficulty trying to import an xml epg into RS using xepg. I'm not the only one as others have exactly the same problem. The only way i can get an epg is to import into DVBViewer, then reinstall rs.
Anyone get this problem and fix it?
Thanks
I do it via Eventghost whenever I press the green button on the remote. I used to have it work with an rec. Service task but someday it stopped working and I could't get it to work again so I switched and press the button once a week and all is good.
"the error"? What is the error. I can succesfully import epg into RS and then get EPG into DVBViewer via the receive epg from service button in the DVBViewer options. But I did have problems automating it via a RS task sometime.
