How can I scan HD feeds in Dvbviewer?
Osti2
Hi guys!
I can't scan DVB-S2 feeds inside DVBViewer. In transedit editor apperar DVB-S2 option when you scan but I can't fins any option inside Scan Channel in Dvdviewer. Any help?
Signalé par stanley_cassidy le 26/12/2010 à 18:43
2 Commentaires
Atlantic Bird 1 (12.5°W)
Fréquence: 12640 - Pol: H - SR: 15000 - FEC: -
Catégorie: Sport - Football américain
Transmis en: MPEG-4
Infos: NFL muxx(dvb-s2,hdtv)
ok, you'll need transedit. Open the corresponding transponder.ini (e.g. Atlantic Bird 1 at 12.5°W), add the transponder parameters and scan or click on analyze. If the feed is still on and the parameters are correct, you'll see the feed (provided it's not scrambled ;) )
..depending on your dvb-s2 card you may have to enter more paramters than posted by cassidy. In my screen shot you can see a lock from 05-12-2010. :bye:
