chrisdvb Posted January 2, 2011 Posted January 2, 2011 For some channels here in Belgium, there are both an english and a french audio channel. The recording service web interface only displays the first available channel so it's impossible to record the other one. Is there a workaround or am I doing something wrong ? Christian
majstang Posted January 2, 2011 Posted January 2, 2011 The recording service web interface only displays the first available channel so it's impossible to record the other one. ?? where do you see that in the webinterface? Would it help maybe if enable "All Audiotracks" under WebinterfaceConfiguration/Recorder/Format Options?
Tjod Posted January 2, 2011 Posted January 2, 2011 Or open the channel list editor in the DVBViewer an drag & drop you preferred audio channel on the first place of the channel.
chrisdvb Posted January 2, 2011 Author Posted January 2, 2011 Thanks for the tips. Here are two images explaining the problem more clearly. In the channel list editor, one can see BE HD (eng) and below, BE HD (fre). In the web interface, only BE HD (eng) appears in the list. I managed to switch fre and eng audio channels to put the french channel first in the channel list editor but the web interface does not get updated (I tried to restart the service but without success). Two questions : what should I do to update the web interface and also, the display of one audio channel only, is this a bug or a limitation ? It might be that setting "all audio channels" as stated above might help but I don't see any changes in the web interface as already explained.
Tjod Posted January 3, 2011 Posted January 3, 2011 If you change the channel list in the DVBViewer (same PC/folder as the Recording Service) an restart the Recording Service (or the PC) it should appear in the web interface.
ml 05019 Posted January 3, 2011 Posted January 3, 2011 I managed to <...> put the french channel first in the channel list editor Your screenshot show you didn't or you took it before you changed the list?
chrisdvb Posted January 3, 2011 Author Posted January 3, 2011 Yes, I took the screenshot before I changed it . The Web interface channel list did finally update after a while so it's fine. Thx all for your help.
