recording unusable
marek dyjor
There is real problem with recording TV.
I’ve got 2 x Technotrend TT-Budget S2-3200 and they work perfectly.
If I start recording I could not change channel, changing is putting recording on hold, not breaking but holding! If I come back to the recorded channel, process of recording is continuing.
More, if I change channel and start recording another show, effect is same.
If I'm checking recording status dialog, I could see that cards have allocated channels for recording, but nothing is really recorded.
I have impression that recent version of DVBViewer pro was recording perfectly.
How to post problems/bugs correctly:
Always follow these instructions. Otherwise no one can - or wants - to help you!.
