DVBviewer Recording Service does not show crypted channels with Terrat
Morten L
Hi
I have used DVBViewer 4.5.0.0 and Recording Service 1.6.8.2 for a while with a cheap DVB-T USB stick and Haupauge Win-CI without any problems.
I have now tried with a Terratec H7 USB with build-in CI/CAM module.
Terratec H7 works very fine when used local in DVBViewer without RS. I can se free and pay channels (Boxer, Denmark) without any problems.
But, when using Recording Service only the free channels are showing up in DVBViewer - the crypted channels dosn't show - black screen, no sound. When I record the ts stream is empty.
I have tried diffent BDA drivers - same result. I have also tried different H.264 codecs but the most stable i MS DTV-DVD driver.
Please help me!
Kind regards Morten Lassen, Denmark
I have investigated som more...
The CAM menu is active when using TerraTec H7 local. When using via Recording Service the CAM menu is inactive and therefore RS can't decrypt.
/Morten
I have the same problem. I'm also using the Terratec H7. I had to reinstall earlier version. 1.6.5.2, for example, works with H7 and encrypted channels.
/Anders
1. Stop the service
2. find the svchardware.xml
3. change
	<entry name="Vendor">4</entry>
to
	<entry name="Vendor">5</entry>
4. start the service.
Does this help?
1. Stop the service
3. change
to
Does this help?
Thanks Lars - it worked like a charm :biggrin:
But scan hardware overwrites svchardware.xml back til normal so after changing svchardware.xml don't touch the scan button.
yes I forgot to mention this. :blush:
Thanks for the feedback, we will correct the wrong detection in the next version. :)
