RedDwarf Posted January 8, 2011 Posted January 8, 2011 (edited) I am having a problem with DVBViewer 4.5 where the quality meter reporting has disappeared on the DVBViewer window. I uninstalled DVBViewer and re-installed which took some time re-setting up and it worked briefly but then stopped working again again a few minutes later. How can I get the signal reporting working properly as I need it because of marginal signal levels which can affect recordings? support.zip Edited January 8, 2011 by RedDwarf Quote
RedDwarf Posted January 8, 2011 Author Posted January 8, 2011 DVBViewer 4.5 Windows XP Pro x86 Gigabyte GA-X48-DS5 with Q9450@2.66GHz Mystique Dual DVB-S2 PCI-e nVidia Zotac GT 240 1GB support.zip Quote
Derrick Posted January 8, 2011 Posted January 8, 2011 ..what happens when you click with the mouse pointer on this field? Quote
RedDwarf Posted January 8, 2011 Author Posted January 8, 2011 ..what happens when you click with the mouse pointer on this field? lol Thanks, after a few clicks it restored the signal level report. Quote
Griga Posted January 8, 2011 Posted January 8, 2011 DVBViewer displays values reported by the driver. It's highly device/driver dependent. Reporting such issues without specifying the device is useless. Quote
RedDwarf Posted January 8, 2011 Author Posted January 8, 2011 DVBViewer displays values reported by the driver. It's highly device/driver dependent. Reporting such issues without specifying the device is useless. Reporting one minute and then not a few minutes later? Is that really likely to be a driver issue. I have been using DVBViewer for quite some time, not that you would know that and haven't had the problem before. Quote
Griga Posted January 8, 2011 Posted January 8, 2011 Ok. Derrick has hit the mark. I didn't. I assumed another Blackgold DVB-T2 device. There are already numerous reports about wrong signal levels due to a driver issue. Quote
RedDwarf Posted January 8, 2011 Author Posted January 8, 2011 Ok. Derrick has hit the mark. I didn't. I assumed another Blackgold DVB-T2 device. There are already numerous reports about wrong signal levels due to a driver issue. I didn't realise that there were any DVB-T2 PC cards available. The last time I looked there were no chipsets/tuners available. Sounds like typical Blackgold driver issues, so it sounds like nothing has changed. Quote
