daveyboyc Posted January 9, 2011 Posted January 9, 2011 Hi, I'm currently testing out RS with a 10 DVB-S tuner PC. I'm using multiple plugins in RS for getting my premium content and although this works, I can only record 1 premium channel at a time(per tuner). I had some different settings before and was able to record more that were on the same transponder(i.e more than 1 channel per tuner). This can be done easily with FTA. Does anyone know if there are special settings for getting more per transponder? ITs possible in programs such as "4therecord" where u can do it by increasing the "CAM" limit. Is it possible in RS? Thanks in advance.
Derrick Posted January 9, 2011 Posted January 9, 2011 ..the limit is 1 scrambled channel/CI. Obviously you are not using a CI -> topic closed (§13 forum rules)!
