I just lost all channels and new search says zero channels found
temeteus82
Hi all!
Firstly I got FireDTV box and I live in Finland.
Our terrestrial operator decided to re-arrange the channels and after this update DVBVierwer isn't able to find any channels at all. I was pondering if we have here some one in Finland with similar issues or some one that had similar issues after changes to channels by the operator.
Try TransEdit (membersarea) and see if you can find your channels with it.
Yeah I did some scanning with it and the result was the same. Anyway tested indoor antenna and it worked just fine... Now the issue seems to be in the antenna cables coming from the flats areal... So problem solved :)
