DVBViewer filter
mahboub
Hi
What's the graph filter of DVBViewer?
Regards,
Mahboub
In fact, DVBViewer's display and recording quality is very good.
So If I know which graph file you use in DVBViewer, maybe I can use it in other DVB software like progdvb...., to get best results.
Best Regards,
Mahboub
Guest Oliver
First of all: The display quality is solely dependant on the MPEG-decoder. There is no special graph file. With the full version of the DVBViewer you can choose all registered decoders. The NVIDIA decoder, the GPL MPEG decoder and the Mediamatics (DVDExpress) decoder have the best quality.
The full version of the DVBViewer won't use a graph for recording any longer with one of the next releases, the data will be taken directly from the transport stream provided by the driver (actually only the videorecorder plugin 2.8 does this yet).
Bye
with fullversion you can use graphedit (connect to remoute graph) to show the exactly graph.
But this not reflected the way of recording!
Steffen
