Problem reading user manual
dvbwatcher372
I just downloaded the current English user manual (DVBViewer.chm). For every topic I click, I get the message
Navigation to the webpage was canceled
What you can try:
retype the address
I have tried opening it directly (both in the DVBViewer folder and elsewhere) and opening from DVBViewer and get the same behavior. Do I need to setup something or is the file corrupted?
  • 1 month later...
The OP has probably figured this out by now, but this is generally caused by Windows 7's default block on downloaded files. right-click on the file, select properties, and click on the "Unblock" button.
