Anysee E30 Paytv-channels
Zooleri
Hello,
Freeair channels working perfectly, but do i need some plugins for conax (encrypted) channels ?
http://anysee.com/eng/product/anyseeE30Plus.php
Is it possible to somehow config Anysee own remotecontrol to work perfectly on DBViewer, or should i buy new remote ?
please answer does this work and support these Encrypted channels at DVBViewer, bought this dvb for this card, cause i need those paytv-channels
does any other Usb-card support these paytv channels ? reply if you have knowledge :)
There is no CI support for anysee cards. Und before you continue please make sure you read the forum rules (§13 especially).
nice, nice then
wasted 15€
Really thought i would use this anysee on DVBViewer, cause i was confused i wrote this thread then.. Second thing i was trying to search compatible paytv cards page, but no luck.
I didnt fully understant rules, cause im new on computer digital-tv scene. Threating on first post is scary
..it's very easy to understand. Without CI no questions about paytv :bye:
i mean these "conax" channels they are encrypted and when insert card for anysee it start showing those channels, for example at W7 media center and Anysee´s own software
edit.
I mean this slot "freeair" encrypted channels i guess these are :unsure:
Anysee e30
Smart Card Slot
● Access to pay TV channels
● Built-in a Smart Card slot
Edited by Zooleri
and i have this real paytv card for this anysee, im not trying any illegal things with this.
So this anysee Smart card module is not supported by DVBViewer, and it wont recognize it ?
please answer so i can forget this :-)
This is not a CI (common interface)
/closed
