juanlu34 Posted February 1, 2011 Posted February 1, 2011 Hello, I bought a dvb-t usb stick (this: ) and me would like to know if you can operate the remote control, the chip is AF9015 BDA Greetings Quote
mobiwan Posted February 1, 2011 Posted February 1, 2011 I have MobiDTV Dual DTT stick. Similar remote and chipset. It's rubbish anyway, the remote never worked properly even in supplied application, and not enough buttons for DVBViewer. Unless someone has a plugin, or WinLIRC can "see" it, it's not going to work I have also PCI Technotrend card and use the Remote eye on it. I have a decent Technisat remote handset. Nearly enough buttons on it. Sadly the Technisat 4 direction keys are same buttons as channel + - and Volume + - Since I have Favorites and TV and/or Home Theatre Remotes for Volume, I set the arrow key for OSD navigation and no ch+1, vol +- You could buy a MS MCE remote. Or add a WinLIRC eye and use any old Philips remote. Quote
