wikings1 Posted February 11, 2011 Posted February 11, 2011 Hello i have problem whit sd channels stuttering not all butt many its disipear if i change from wmr9 to other. But wmr9 have the best picture for sd channels. i Have the latestdvbviewer win 7 64 bit nvidia 250 whit latest drivers i have god signal on all the channels(110 cm Motorized dish) anu one have any clue about this stuttering regards wikings1 Quote
wikings1 Posted February 11, 2011 Author Posted February 11, 2011 (edited) zip file hmmm cant get the zip file upploaded Edited February 11, 2011 by wikings1 Quote
test Posted February 11, 2011 Posted February 11, 2011 latest NVIDIA driver? I bet it's a drivers problem. Did you check DPC Latency with DPC Latency Checker? I think you'll have sporadic dropouts with a latency >1000ys Please also test with NVIDIA driver v258.96. Quote
wikings1 Posted February 12, 2011 Author Posted February 12, 2011 Thanks Test seems to work i unboxed nvidia vrm fix to Thanks again regards wikings1 Quote
wikings1 Posted February 28, 2011 Author Posted February 28, 2011 Didnt work perfect i still have stuttering on sd channels if i start whit a sd channels it seems to work but when i go from hd channel to sd its starts to stutter some channels are worse than others sky news on thor 0.8 w is one whits stutter. if i change from wmr9 to other render it works god but picture quality is worse any one else whit same problem regards wikings1 support.zip Quote
