htpc_diy Posted February 11, 2011 Posted February 11, 2011 (edited) Dear all, I suggest designing a new OSD skin just like the pictures attached. Is there any one can generate the new skin? Edited February 11, 2011 by htpc_diy Quote
htpc_diy Posted February 11, 2011 Author Posted February 11, 2011 Dear all, I suggest designing a new OSD skin just like the pictures attached. Is there any one can generate the new skin? Quote
Gioxy Posted February 11, 2011 Posted February 11, 2011 You can do it yourself... have a look to OSD-Skin Editor Wiki page (in German, unfortunately; you can eventually use a on-line translator...) Quote
htpc_diy Posted February 13, 2011 Author Posted February 13, 2011 (edited) Dear Gioxy, Thanks for your rapid response. Do you have any detailed tutorial of the Skin Editor software? I need to learn how to generate a entirely new OSD skin before DIY. Of course, I''ll share the New OSD skin to all in the forum once it get ready. Edited February 13, 2011 by htpc_diy Quote
Tjod Posted February 13, 2011 Posted February 13, 2011 You should start with an existing Skib e.g. the Default Skin. And change the layout page by page. DVBViewer Spy (Members Section) can be help full to. It shows all variables and there values. Quote
