Terrestial and DVBviewer ?
darkhorse
Hi.
I have purchased a USB DVB-T sticker via ebay.
It works ok with Blazevideo, and Windows Media Center.
Can it also work with DVBViewer ?.
I have DVBViewer set up, but have problems.
I have choosed Terrestial, and Astra.
I can see, that local Terrestial channels has been found.
But if I click on one of the channels, DVBViewer closed down and exit.
What could be reason(S) ?
FYI:
The USB DVB-T is a WinFast DTV dongle GOLD DBA Filter Afatech-DVB-T
Any comments please :-)
Please post some more information:
http://www.DVBViewer.tv/forum/index.php?showtopic=2210
Hi Lars_MQ
Thanks for the reply. I have attached the result now from the support tool to this reply.
I also have attached the compatibility information. There seems to be issues there.
Is that ok info?. Need more, please tell me it :-)
DVBViewer is version DVBViewer Pro V4.6.0.1
You may use the stick in DVBViewer or in the Recording Service, but not in both!
Edited by Griga
translated from German
Does that mean, to uninstall for instance Recording Service ?
I installed DVBViewer on my Windows XP now.
There are progress then, but I cannot see/view the channel. Just hear the audio.
What could be the reason ?. What more infos do you need to help me ?
I have attached a pict.
  • 8 months later...
Find the right video decoder under "Indstillinger" and "DirectX"
