EMP Centauri 8/1 diseqc switch settings
Habos
Hi
I didn't use DVBViewer for a long time, was on linux with vdr.
I would like now with my new sat. configuration to switch to windows and DVBViewer, but before I do that
I would like to know how to configure DVBViewer/transedit to work with my switch (emp centaury 8/1).
I have a Mystique SaTiX-S2, both tuners connected to a emp centaury 8/1 switch and those connected to 8 inverto dual lnbs.
In vdr I use the follwoing diseqc.conf
# DiSEqC configuration for VDR
# Format:
# satellite slof polarization lof command...
# satellite: one of the 'S' codes defined in sources.conf
# slof: switch frequency of LNB; the first entry with
# an slof greater than the actual transponder
# frequency will be used
# polarization: V = vertical, H = horizontal
# lof: the local oscillator frequency to subtract from
# the actual transponder frequency
# command:
# t tone off
# T tone on
# v voltage low (13V)
# V voltage high (18V)
# A mini A
# B mini B
# Wnn wait nn milliseconds (nn may be any positive integer number)
# [xx ...] hex code sequence (max. 6)
# The 'command...' part is optional.
# Examples:
# DiSEqC Schalter EMP Centauri DiSEqC 1.1 (DiSEqC 1.2, Goto- X, USALS)
# Input 1 - Astra 1 19.2E - uncommited switch input 1
S19.2E 11700 V 9750 t v W15 [E0 10 39 F0] W15 [E0 10 38 F0] W15 t
S19.2E 99999 V 10600 t v W15 [E0 10 39 F0] W15 [E0 10 38 F0] W15 T
S19.2E 11700 H 9750 t V W15 [E0 10 39 F0] W15 [E0 10 38 F0] W15 t
S19.2E 99999 H 10600 t V W15 [E0 10 39 F0] W15 [E0 10 38 F0] W15 T
# Input 2 - Hostbird 13E - uncommited switch input 1
S13E 11700 V 9750 t v W15 [E0 10 39 F0] W15 [E0 10 38 F4] W15 t
S13E 99999 V 10600 t v W15 [E0 10 39 F0] W15 [E0 10 38 F4] W15 T
S13E 11700 H 9750 t V W15 [E0 10 39 F0] W15 [E0 10 38 F4] W15 t
S13E 99999 H 10600 t V W15 [E0 10 39 F0] W15 [E0 10 38 F4] W15 T
# Input 3 - Hispasat 30W - uncommited switch input 1
S30W 11700 V 9750 t v W15 [E0 10 39 F0] W15 [E0 10 38 F8] W15 t
S30W 99999 V 10600 t v W15 [E0 10 39 F0] W15 [E0 10 38 F8] W15 T
S30W 11700 H 9750 t V W15 [E0 10 39 F0] W15 [E0 10 38 F8] W15 t
S30W 99999 H 10600 t V W15 [E0 10 39 F0] W15 [E0 10 38 F8] W15 T
# Input 4 - Astra 23.5E - uncommited switch input 1
S23.5E 11700 V 9750 t v W15 [E0 10 39 F0] W15 [E0 10 38 FC] W15 t
S23.5E 99999 V 10600 t v W15 [E0 10 39 F0] W15 [E0 10 38 FC] W15 T
S23.5E 11700 H 9750 t V W15 [E0 10 39 F0] W15 [E0 10 38 FC] W15 t
S23.5E 99999 H 10600 t V W15 [E0 10 39 F0] W15 [E0 10 38 FC] W15 T
# Input 5 - Astra 28.2E/Eurobird 28.5E - uncommited switch input 2
S28.2E 11700 V 9750 t v W15 [E0 10 39 F1] W15 [E0 10 38 F0] W15 t
S28.2E 99999 V 10600 t v W15 [E0 10 39 F1] W15 [E0 10 38 F0] W15 T
S28.2E 11700 H 9750 t V W15 [E0 10 39 F1] W15 [E0 10 38 F0] W15 t
S28.2E 99999 H 10600 t V W15 [E0 10 39 F1] W15 [E0 10 38 F0] W15 T
# Input 6 - Eutelsat W1R - uncommited switch input 2
#S10E 11700 V 9750 t v W15 [E0 10 39 F1] W15 [E0 10 38 F4] W15 t
#S10E 99999 V 10600 t v W15 [E0 10 39 F1] W15 [E0 10 38 F4] W15 T
#S10E 11700 H 9750 t V W15 [E0 10 39 F1] W15 [E0 10 38 F4] W15 t
#S10E 99999 H 10600 t V W15 [E0 10 39 F1] W15 [E0 10 38 F4] W15 T
# Input 7 - Sirius 2/3 - uncommited switch input 2
#S5E 11700 V 9750 t v W15 [E0 10 39 F1] W15 [E0 10 38 F8] W15 t
#S5E 99999 V 10600 t v W15 [E0 10 39 F1] W15 [E0 10 38 F8] W15 T
#S5E 11700 H 9750 t V W15 [E0 10 39 F1] W15 [E0 10 38 F8] W15 t
#S5E 99999 H 10600 t V W15 [E0 10 39 F1] W15 [E0 10 38 F8] W15 T
# Input 8 - Amos 1 - uncommited switch input 2
#S4W 11700 V 9750 t v W15 [E0 10 39 F1] W15 [E0 10 38 FC] W15 t
#S4W 99999 V 10600 t v W15 [E0 10 39 F1] W15 [E0 10 38 FC] W15 T
#S4W 11700 H 9750 t V W15 [E0 10 39 F1] W15 [E0 10 38 FC] W15 t
#S4W 99999 H 10600 t V W15 [E0 10 39 F1] W15 [E0 10 38 FC] W15 T
Reading the transedit manual the diseqc configuration would look like somthing like this:
switch - uncommitted - 0
internal - delay - 15
switch - committed[unchanged] - 1
switch - committed[unchanged] - 2
switch - committed[unchanged] - 3
switch - committed[unchanged] - 4
and same for the remaining 4 position with switch - uncommitted - 1.
Can someone confirm this is the way I need to go.
Thx
..take transedit and give it a try ;) Use extended to edit the diseqc commands to your needs. The additional delays are imho not necessary but of course feel free to add delays. After you've found the correct commands you can scan with transedit and export the lists to DVBViewer.
Here's what I think Amos should look like according to your table.
Thx for your answer
Finally managed yesterday to give it a try (had some problems with my hard disk).
I needed to setup like this:
sat1 -> uncommitted - 1 committed[unchanged] - 1
sat2 -> uncommitted - 2 committed[unchanged] - 1
sat3 -> uncommitted - 3 committed[unchanged] - 1
sat8 -> uncommitted - 8 committed[unchanged] - 1
Not sure if the committed[unchanged] is needed.
Works very well even faster then then it worked on vdr.
