avermedia dual DTT pci-ex at resume not work
ksp
Hello please help for trouble..
1x pci skystar HD
1x usb skystar HD2
1x avermedia AverTV Duo Hybrid PCI-E II (A188) (dual DTT or dual analog)
O.S. w7 x32 pro
- Restart or power on ALL works:)
- Resuming from hybernate/standby;
skystar(s) all ok with sat channels but
change to DTT channels avermedia not work black screen;
if shut down dvbwiever and startup avermediacenter or w7mce (without restart pc)the avermedia return to go;and then I startup dvbwiever again then avermedia go.
OR
removing and refind avermedia card on hardware menu of dvbwiever then avermedia go.
Drivers last for avermedia 1.3.0.76 installed (I try others way for 1 month..)
Plese note I have not trouble using w7mce and this avermedia at resume or restart PC.
Thank's for any idea.
  • 3 weeks later...
I have the same problem.
I think is a driver problem with W7 x86.
Now,i solve it with powertrigger....i cinfigure it to stop the avermedia driver before suspend and start avermedia driver on wake up.
I hope in a new driver....
  • 3 months later...
Hi
I use same card with XP sp3 DVBViewer 4.8.0.1 and same problem (old versions also didn't work fine)
After wake up, not work.
my driver version is the same that you and Avermedia no updating drivers from juny 5th of 2009
Anybody know any "patch" for this issue or have tested with another software ?
Cheers
