Cannot View HD channels
silvion
Hi to all this is my first post and as you can understand a new user. I have a Skystar2 working with Dual core PC on XP OS sp3 everything was working fine but as from 20 Feb 2011 no HD channels are available I scanned and updated the channel list using DVBViewer but nothing I also downloaded an updated transponder list available on this forum but still nothing any help please
thank you in advanced.
HD channels are quite often broadcast using DVB-S2 and not DBV-S. Does you tuner card support it? The normal Skystar 2 doesn't...
Edited by jf2020
