EPG language doesn't change
vaskoul
Hi there!
I've installed DVBViewer Pro 4.6.0.1 and I encounter this problem:
Although the channels I receive have greek EPG (my TV set automatically receives it), DVBViewer insists showing only english EPG.
Even though I set in Options->EPG->Preferred language->Greek, I still don't get greek EPG.
What can I do?
Thanks.
Can you please zip and upload the epg.dat from the configurationfolder of the DVBViewer, so I can take a look at it?
Thank you. The greek is all there. Strange.
Could you please zip and upload also your channels.dat file? I'll need the fitting channels to test it in the DVBViewer. :)
OK!
Thank you for your interest. I created and attached the support.zip file as well.
channels.zip
Edited by vaskoul
Well it works without problems here. You just have to select
Greek, Modern (1453 -) (gre)
in the EPG options and then restart the DVBViewer.
You are right, that solved the problem. :biggrin:
Thank you very much!
