grandmultigame Posted March 1, 2011 Posted March 1, 2011 I'm trying to post a new message, but when running supporttool in the DVB-Wiever dir, it should generate the file: C:\ProgramData\CMUV\DVBViewer\support.zip However, this file and dir does not exist on my computer and therefore I can't upload it. What can be done? Kind regards, Hans Quote
grandmultigame Posted March 1, 2011 Author Posted March 1, 2011 Hello. I´m using TV-card: Technotrend C 1501 DBC-C, driver version: 5.0.1.8 Motherboard: Manufacturer ASUSTeK Computer INC. Model P5VD2-MX Chipset Vendor VIA Chipset Model P4M890 Video Card: NVIDIA GeForce 8600 GT, Physical Memory 256 MB Virtual Memory 1504 MB Driver version: 8.17.12.5896 My problem is that when watching TV-channels in DVBViewer there is squares in the picture and also in the .ts file recorded by DVBViewer. I have tried different setups in the Direct X menu. What can be done? Kind regards, Hans Quote
grandmultigame Posted March 1, 2011 Author Posted March 1, 2011 Problem solved. No need to reply. Quote
grandmultigame Posted March 1, 2011 Author Posted March 1, 2011 I better make it more precise: Problem solved with uploading support.zip However I'm still having problems with squares in the picture. Help is appreciated. Kindly regards Hans Quote
