Default Audio Language
hax169
i'm trying to select english as default audio so i don't have to switch it manually after tunning the channel. is there a way to do it like you would do on a STB?
i'm using windows 7 x64 & DVBViewer pro 4.6.0.1
Dunno how you select default audio on your STB, but for the DVBViewer you have to open the channel list editor and then drag the wanted audio track on the channel name.
thanks a lot, it works fine :)
in most STB you choose a list with your favourite languages by order
example:
1st-english
2nd-spanish
3rd-german
Edited by hax169
