TranseditMMC: problem
Ok here is an odd one.
When i try to scan with Transedit.exe, the exe being inside the DVBViewer main folder, i get no channels detected
When i scan with Transedit.exe on a separate folder, then i get results.
Problem is i can't export the channels so i need it to work inside the DVBViewer folder.
Edited by themaster1
Use TransEdit 3.6.4 from the Members Section not the demo version Transedit MMC.
Transedit MMC
TransEdit ist a tool to administrate and update your channel lists. The free available version is some sort of technology demonstation in order to show you if the DVBViewer is able to deal with your DVB Card, while scanning works like charm and the save as well as the preview function are disabled.
