bfc_xxx Posted March 14, 2011 Posted March 14, 2011 Hi! I am interested to buy DVBViewer but since there is no demo or trial I want to ask if there is any skin that it has the channel list in the same window. If anyone can provide skin screenshots it will be welcome. Also it is a shame that there is no trial because I can't test if dvbs2 channels will work nice with my card and pc. Quote
ElecardFAN Posted March 14, 2011 Posted March 14, 2011 Well i'm not sure what you understand by asking about the channel list in the same window? The channel list can be provided either with direct epg informations and/or without. You can either use the channel list in a complete osd window frame or blitted transparent into the display. You are also able to dock the channel window to the main window - if you prefer the regular windows control elements. Since you are a a member of the forum you can easily scroll through the skins listed in the osd skin section. Peter Quote
bfc_xxx Posted March 14, 2011 Author Posted March 14, 2011 Ok Peter, thanx for the info. I ordered DVBViewer. Quote
