TechniSat SkyStar USB 2 HD CI with DVBviewer Pro
leeva
My new TechniSat SkyStar USB 2 HD CI works fine with DVBViewer TE Edition but i can't make it works with the pro version (v 4.2.1.0).
When i try to view an encrypted channel, it keep telling me that i have to check my rights.
The compatibility tool tells me, that my DVB card is OK and the CI is supported but it does not work.
I also have acces to the module Cam and i can check my Aston V2.1900.
I have tested the DVB card on two différents computers: One with XP SP3 and the second with Vista 32, but on both i have the same result.
Thanks
(v 4.2.1.0)
Please install first the latest version (4.6).
jf2020 Thanks a lot, with the V 4.6.0.1 it works fine.
