newOSD 0.9rc1
Guest Lars_MQ
The last round before the final release of the newOSD Plugin.
The newOSD Plugin give you the ability to apply skins to the DVBViewer OSD.
What you need:
Fullversion DVBViewer Version 2.2.
In older versions you may activate the plugin but it will lead to an instant crash of the DVBViewer!
You need also GDI+ Support. In Win XP and W2003 ist buildt in. For any other OS:
If newOSD won't work, you can download GDI+ here:
Microsoft
Installation of newOSD 0.9 RC1
Simply copy the file newOSD.dll into the pluginsdirectory of DVBViewer. After a restart of the viewer it will be available.
Activating the newOSD
You have to activate newOSD within the DVBViewer settings. In menu "Settings" -> Options -> Teletext & EPG -> with the dropdownlist besides the transparency settings you can select newOSD.
If newOSD is not found in that list, check if there is a newOSD.dll in the pluginsdirectory and restart the DVBViewer.
Customizing newOSD
The newOSD can be customized in the optionsdialog (Menu Plugins -> OSD -> Options).
The options in detail:
    - Skinfile:
        Here you can select the skin.
    - Imagespath:
        Is needed für several additional functions of the OSD. It should point to the above mentioned "Images"-dir.
I also put a few Skins online. Remember they're also rc1 ;)
Installing the OSDSkins
The OSDSkins consist of a directory and serveral files (and maybe subdirs). First create, if not existing, within the DVBViewers directory a directory called "Images". That's the place we will keep all OSDSkins. Simply copy the OSDSkindirectory into "Images"-dir.
And last but not least I've uploaded the TV-Station-logopack.
I will publish the osdSkineditor within the next days and also some osdplugin (the famous games :) ).
Remember, it's a Release Candidat. That means, it runs well enough to be plublished, but there may be some bugs in it.
Have fun
lars
GREAT !!!!!!!
Edited by skandler
