janip Posted March 24, 2011 Posted March 24, 2011 Did i miss something? Why Autosearch Timer is missing? There is no info in wiki. No matter, if service do that automatic every 12h. I want run it now. And what happens those unicode? Everything work earlier. http://japesone.kapsi.fi/gallery/Images/kavija_kuvat/No_Autosearch_Timer.jpg Wiki: ----------------------------------------------------------------------------------------- New Timer With the Dropdown Box at the Button New Timer you choose the kind of Timers. There are the following choices: * Recording Timer * Search Timer * Autosearch Timer (this one is needed for processing Search presets automatically and creating the timers. Periodical all 1-2 Days would be a good value.) * Prozess Task Timer A click at New Timer opens the window for the timer ----------------------------------------------------------------------------------------------
RalleN Posted March 24, 2011 Posted March 24, 2011 I suggest you are using the latest version (>= 1.7) of recording service. If so take a look at the release notes for version 1.7. Here you can read: # Change: Webinterface: Auto search timer entry removed from the new timer selection. You can use a internal process timer for this now. Following this create a new process timer with action auto search.
Tjod Posted March 24, 2011 Posted March 24, 2011 Use the "Internal Task timer" > Internal Task: Auto Timer
janip Posted March 24, 2011 Author Posted March 24, 2011 I try to find word "Autosearch timer" to change log, but there is mistake. Change: Webinterface: Auto search timer. And i look, autosearch to internal task, but that is auto timer. Doh... Why autosearch wont start, when i run epg update to DVBViewer?
majstang Posted March 24, 2011 Posted March 24, 2011 Why autosearch wont start, when i run epg update to DVBViewer? Maybe cuz this box is not checked: Changelog RS 1.6.9: Add: Configuration program: Added the option “Execute Autosearch after EPG Update” in the EPG options.
janip Posted March 25, 2011 Author Posted March 25, 2011 It is checked. What is that no name check box over that “Execute Autosearch after EPG Update” box?
