latdna Posted March 25, 2011 Posted March 25, 2011 How to modify "Streaming" feature inside webinterface so it won't ask questions about how it will stream. I would want it to "Direct Stream" with TS without biljon questions directly when you press the channel logo. Should be possible since you can edit html files but anyone know how to edit?
latdna Posted April 14, 2011 Author Posted April 14, 2011 Made little modification to global.js: Before: function popupStream(URL) { if (URL!="") { var topP = (screen.availHeight - 600) / 2; var leftP = (screen.availWidth - 600) / 2; var popupwindow =window.open(URL, '_new3', 'width=600, height=600,top=' + topP + ',left=' + leftP +', scrollbars=yes, resizable=yes'); popupwindow.focus(); } } After: function popupStream(URL) { if (URL!="") { var splitKanava = URL.split("="); if (splitKanava="channel") { var splitKanava = URL.split("="); kanava = splitKanava[splitKanava.length-1]; window.location = "http://192.168.0.2:8001/index.html?stream=start&ip=192.168.0.2:7522/upnp/channelstream/"+kanava+".ts&player=VLC" } if (splitKanava="recID") { var splitKanava = URL.split("="); kanava = splitKanava[splitKanava.length-1]; window.location = "http://192.168.0.2:8001/index.html?stream=start&ip=192.168.0.2:8001/upnp/recordings/"+kanava+".ts&player=VLC" } } }
latdna Posted April 14, 2011 Author Posted April 14, 2011 Forget the first one, it has a bug. File: C:\Program Files (x86)\DVBViewer\SVCweb\global.js Before: function popupStream(URL) { if (URL!="") { var topP = (screen.availHeight - 600) / 2; var leftP = (screen.availWidth - 600) / 2; var popupwindow =window.open(URL, '_new3', 'width=600, height=600,top=' + topP + ',left=' + leftP +', scrollbars=yes, resizable=yes'); popupwindow.focus(); } } After: function popupStream(URL) { if (URL!="") { var splitKanava = URL.split("="); kanava = splitKanava[splitKanava.length-1]; if (URL.search("&chid")>0) { window.location = "http://192.168.0.2:8001/index.html?stream=start&ip=192.168.0.2:7522/upnp/channelstream/"+kanava+".ts&player=VLC" } if (URL.search("&recid")>0) { window.location = "http://192.168.0.2:8001/index.html?stream=start&ip=192.168.0.2:8001/upnp/recordings/"+kanava+".ts&player=VLC" } } }
