gefut Posted April 1, 2011 Posted April 1, 2011 First of all i would like to say that i'm using since quite a long time DVBViewer and i'm very happy with it. Unfortunately i recently upgraded my skystar USB 1 to a skystar USB 2 HD CI and it doesn't work on the HD channels. I use the latest DVBViewer 4.6.01 and use windows 7 (32 or 64 bit version). I have the latest drivers for the skystar (1.0.5.702). During the scan it does not detect the HD channels ( tried also with transedit 3.7.1.0) If i use a preconfigured channellist and want to look a HD channel it will not open the channel and de window stays black. If afterwards i want to go back to a normal channel it will not open it anymore. I have to reboot the pc to have it working agian on normal channels. I tried on 2 diffent PC but with the same prob. (both windows 7 but 32/64 bit I tried another DVBViewer (dvbdream) and with it it works fine (finds HD channels during scan and viewing without prob). Could you please be so kind to help me out with this matter? Thanks for your answer. Intel® Core i5 CPU M 430 @ 2.27GHz Intel® HD Graphics NVIDIA GeForce GT 325M ACPI x86-based PC[/font] support.zip Quote
