tune the frequency of the problem
velehof
My problem with the tuning frequency on the 23,5 ASTRA 3D - 12109 / H 27500 3/4 SkyLink (Czech republic)
My Device SkyStar USB 2 HD CI.
DVBViewer TE2 -frequency to tune it without problems.
DVBViewer demo-frequency to tune it without problems.
DVBViewer PRO -not tune the frequency(as official soft Version 4.6.0.1).
The problem is troubling me a long time and I can fully use the DVBViewer PRO.
Thanks for the advice
velehof
The Demo uses the same code for tuning as the DVBViewer Pro, so most likely you have problems with your settings for the channel...
Thank you problem solved
velehof
