epg to xml file.
Any change to get direct epg .xml output from recservice?
Sory, i mean that recordings epg infofile, what recservice do when i select it from settings.
I need that for xbmc, don't know if that .nfo xml is universal?
Maybe that same file works windows mediacenter too?
XBMC can use epg inside .ts too, but i encode all my recordings to mp4.
I think i need just little converter for that...
