supersaianwu Posted April 5, 2011 Posted April 5, 2011 Hi: I have the lateest RS 1.7.1.1 running, when selectiing a channel to stream, mobile safari's debug console shown me a java script error of functions.js TypeError: Result of Expression 'i[o]' [undefined] is not an object The stream config page has nothing shown up for me to select the stream quality, and the aspect ratio is not selectable. If I press stream butyon, the play icon does not show as before when My iphone is at ios 4.1 which everthing is working
supersaianwu Posted April 18, 2011 Author Posted April 18, 2011 Hi: I have the lateest RS 1.7.1.1 running, when selectiing a channel to stream, mobile safari's debug console shown me a java script error of functions.js TypeError: Result of Expression 'i[o]' [undefined] is not an object The stream config page has nothing shown up for me to select the stream quality, and the aspect ratio is not selectable. If I press stream butyon, the play icon does not show as before when My iphone is at ios 4.1 which everthing is working Dear sir: I have attached the support.zip and few pictures captured the screen on iphone. Please help. support.zip Pictures.zip
Lars_MQ Posted April 18, 2011 Posted April 18, 2011 The functions.js is part of the iWebKit library we are using. i have no clue why there is a script error. Can you try to change the language of the recording service to english and test it again? Maybe the problem is related with this. And maybe you can you counter check it with Safari on a PC. You can't stream there, but you should at least see the stream settingspage. Oh and don't forget to turn the UPnP debug logging off again.
