latitudehopper Posted April 8, 2011 Posted April 8, 2011 Hi there. I have a win 7 machine running as my HTPC. I am trying to get DVBviwer to work so I can ditch WMC which is too slow for me. I have one PCIe dual DVB T tuner and one USB DVB-t2 tuner. How can I get it to work so that ALL channels are used including HD and yet it utilizes all three tuners in its working? Many thanks. Jamie Quote
fxv1 Posted April 8, 2011 Posted April 8, 2011 You can set up more than 1 instance of DVBViewer and then assihn 1 tuner for each app...I use 2 tuners and run 2 DVBViewers , works a treat Hi there. I have a win 7 machine running as my HTPC. I am trying to get DVBviwer to work so I can ditch WMC which is too slow for me. I have one PCIe dual DVB T tuner and one USB DVB-t2 tuner. How can I get it to work so that ALL channels are used including HD and yet it utilizes all three tuners in its working? Many thanks. Jamie Quote
latitudehopper Posted April 8, 2011 Author Posted April 8, 2011 What I would like to do is have one instance of DVBViewer and have it use all the channels. It may be a mistake on my part..... thank you all the same... I will report back. Quote
majstang Posted April 8, 2011 Posted April 8, 2011 Investigate the wiki--->channel groups http://en.DVBViewer.tv/wiki/Options_Service_-_Hardware Quote
themaster1 Posted April 10, 2011 Posted April 10, 2011 You can install DVBViewer twice (maybe more?) , read this thread Quote
dvbrewer Posted April 10, 2011 Posted April 10, 2011 What I would like to do is have one instance of DVBViewer and have it use all the channels. It may be a mistake on my part..... thank you all the same... I will report back. I think Griga's post here is relevant? Quote
