Carl Posted April 9, 2011 Posted April 9, 2011 Hi, I have an IRTrans Receiver which has been freashly installed. I have set up the Harmony 525 as a Media Center PC - Microsoft - Mediacenter. WinLirc is ticked in DVBViewer and is working with most commands some have been taught(Learn). When i invoke the OSD Menu i start to navigate with the arrow keys but every key press i get a double key press in DVBViewer, skipping 1 title on the menu each time. Anyone else with a similar problem that have fixed this, or have the best way to set up the Harmony 525 with the IRTrans and DVBViewer? My Wife is getting very frustrated with the lack of options on the remote, and i do value my marriage.. CW Quote
Metylisator Posted April 9, 2011 Posted April 9, 2011 Hi, try to rename apps.cfg in programs/irtrans/remotes in apps.bak. Quote
Carl Posted April 9, 2011 Author Posted April 9, 2011 Hi, try to rename apps.cfg in programs/irtrans/remotes in apps.bak. Hi, Thanks for the reply, i have solved it however. Was really simple, as most obvious things are! I removed the Winlirc Up, Down, Left, Right commands that are preprogramed into DVBViewer and now without the commands even being learnt again it works. I think there must be something in irtrans that creates this as a generic command anyway. However i want to map some additional functions on the Harmony 525 or try a different type of remote installed on the harmony. Any suggestions?? CW Quote
