Bjur Posted April 13, 2011 Posted April 13, 2011 I have a problem. I can't get recording service to stream to a client. I have on my DVBViewer server installed the old VLC 0.86i as I read only that version works. I can only get direct stream to work, but when I want to stream to a VLC client on port 3335 it gives me an error. I'm 100% sure I have forwarded the port on my router, but when I ran a port test it said port 3335 is closed. I have tried to disable windows firewall without any luck. Would really like to get it to work. Any suggestions?
Tjod Posted April 13, 2011 Posted April 13, 2011 Use the current Recoding Service Version 1.7.1.1 and the current VLC Player Version 1.1.9. Ann check the path in the settings http://en.DVBViewer.tv/wiki/Options_Service_-_Web_Settings#VLC_program
Bjur Posted April 14, 2011 Author Posted April 14, 2011 Use the current Recoding Service Version 1.7.1.1 and the current VLC Player Version 1.1.9. Ann check the path in the settings http://en.DVBViewer.tv/wiki/Options_Service_-_Web_Settings#VLC_program Updating the VLC solved the problem. Thx:)
