dgian Posted April 13, 2011 Posted April 13, 2011 I want to use the function ShowPopUp to call some external programs. I have something like this(vbscript): ============================ option explicit dim myDVBViewer dim myOSD sub main() Set myDVBViewer = GetObject(, "DVBViewerServer.DVBViewer") Set myOSD = myDVBViewer.OSD call myOSD.showPopUp("Heading","OPTION1,OPTION2",TRUE) aaa = myOSD.showPopUp.selectedindex if aaa = 0 then msgbox ("OK") end if end sub main ============================== But it doesn't work... Anyone who can help me? Thank you. Quote
nuts Posted April 13, 2011 Posted April 13, 2011 ============================ option explicit dim myDVBViewer dim myOSD dim selectedindex sub main() Set myDVBViewer = GetObject(, "DVBViewerServer.DVBViewer") Set myOSD = myDVBViewer.OSD selectedindex = myOSD.showPopUp("Heading","OPTION1,OPTION2",TRUE) Select Case selectedindex case 0 msgbox ("OK") End Select end sub main ============================== Try this Quote
dgian Posted April 13, 2011 Author Posted April 13, 2011 That worked! I'm realy gratefull.Thank you. Quote
