New RS Task Creation?
oMikR0n
Can you help me how i can create a new RS task which it can restart the service?
For example with an autohotkey script:
Run, Stop Recording Service.bat, C:\Path
Sleep, 8000 ;8 second delay
Run, Start Recording Service.bat, C:\Path
Stop Recording Service.bat:
net stop "DVBVRecorder"
net start "DVBVRecorder"
or batch code only with a 5 second delay:
TYPE NUL | CHOICE.COM /N /CY /TY,5 >NUL
None of these suggestions are tested :bye:
Komisch, woher kennst Du meine Konfiguration :rolleyes: :
PING 1.1.1.1 -n 1 -w 5000 >NUL
Edited by uglyrooster
Thanks a lot for all your help. I tried the last one and worked! :bounce:
And how to restart service from client computer?
Let say i watch DVBViewer on client computer, but image freeze, and i must stop and start again DVBViewer from server pc.
How to do that?
Quite hard when you have a bunch of network security in the way. Have you tried doing it with Windows Remote Desktop?
Maybe PsTools can work http://technet.microsoft.com/en-us/sysinternals/bb896649.aspx
There is a pretty nice solution if you are familiar with autohotkey:
http://www.autohotkey.com/forum/topic21975.html
If running this as a RS task it must be executed silently, cuz otherwise all popups will stall the task.
when i watch tv on client( with dvb recording), and image freeze, i use teamviewer( remote software) conect to server pc, restart dvb server.
on server pc i use an batch:
NET STOP "DVBViewer Recording Service"
NET START "DVBViewer Recording Service"
I do not understand why guys on previous post say to use net stop DVBVRecorder, for all i know, DVBViewer service is:DVBViewer Recording Service
Servicename for DVBVservice.exe is "DVBVRecorder"
Showname is "DVBViewer Recording Service"
Check properties...both works just as well :blink:
