1.7.2 web interface unicode bug
There is still one unicode bug related to AM/PM string (it should show 上午/下午). It is in "Device Status" tab. Thanks.
Locale: Chinese (Taiwan) / non-unicode settings: Chinese (Taiwan), Windows 7 Ultimate.
Forgot to attach the screenshot.
Thank you, I'll fix it. :)
There is unicode related bug in Suomi=Finnish language file.
File is ANSI encoded which causes little rectangles instead of umlaut characters. Workaround: Opening the file in notepad and saving the file in UTF-8 format using 'Save As...' command fixes the issue.
Edited by jakeh
