osdGames
Guest Lars_MQ
I've uploaded then osdGames Plugin to the members area.
osdGames 0.9rc1
The osdGames pack is a little fun for the comercial breaks ;-) Following 4 games are in the pack: Tetris, Pacman, Digger und Snake.
What you need:
Fullversion DVBViewer Version 2.2rc1 + newOSDrc1.
Following Keys should be assigned in DVBViewer Menu -> Settings -> Options -> Control:
Channel Plus * Channel Minus * Volume Up * Volume Down * OSD open/Enter * OSD close * OSD Up (optional) * OSD down (optional).
Installation:
Just copy the osdGames.dll into the plugin directory of the DVBViewer. After restarting the DVBViewer you find the games in the OSD-menu.
You open the OSD-menu depending on your configuration of the above mentioned keys.
To quit a games just press OSD Close. The games are controlled with the Channel Plus / Channel Minus and the Volume Up * Volume Down keys. The OSD open key also is used in the games with different purposes (just try it out :mellow: )
Have fun!
