Search EPG "Ignore case" bug
iriskin
The problem is: "Ignore case" option doesn't affect Epg Search, when search in Cyrillic. In English everything is fine. Examples: when i search for a word in lower case i get no matches(there are no words in lower case in epg)http://imgur.com/a/vJfS4, but when i search same word in upper case i get lots of matches http://imgur.com/a/0G2ca. It doesn't matter if i have "Ignore case" checked or not. Also it doesn't matter what language i set in for RS or preffered EPG.
Edited by iriskin
Confirmed. Fixed it. Thanks for the report.
2nd link fixed:
Thank you, Lars!
Edited by iriskin
