viewemen Posted April 25, 2011 Posted April 25, 2011 Hello, how to have the bar graph of signal quality instead of signal level on DVBViewer Pro? I have DVBViewer GE on signal quality Is there a setting somewhere? Thank you. Quote
themaster1 Posted April 25, 2011 Posted April 25, 2011 If you go to View > Show statusbar you should be able to see it. On the part where there is the "Time 15%" for example click on it several times and you'll see it. For the bit errors it's in: View > filters > dvbSource > discontinuities Quote
viewemen Posted April 25, 2011 Author Posted April 25, 2011 I think I misspoke, I meant how to get the signal quality in place of signal level as DVBViewer GE! thank you as well! Quote
viewemen Posted April 26, 2011 Author Posted April 26, 2011 (edited) shame! it would be nice that they add this feature in future versions! Two bar charts, one for the level and the other for quality as Concur (Progdvb, Smartdvb ... etc.)! example: Edited April 26, 2011 by viewemen Quote
