bambuser Posted April 27, 2011 Posted April 27, 2011 Ok, maybe it's just me... but is it correct that the MHEG-5 Plugins opens with the same key that is assigned to open the OSD-Menu.!? Is there any possibilty to de-link it from the key assigned to the OSD-Menu and assign it to a custom chosen one ? Thanks for help! Quote
mobiwan Posted April 27, 2011 Posted April 27, 2011 Agreed, there is no Remote Keymap. It should either work of a coloured button (not just red, but whatever the broadcaster is using, RTE used green for a while ) or optionally the Teletext key, as in UK it replaces EBU text. In Ireland the Text button should do EBU Teletext or MHEG5 text depending on channel, but there is no Remote Control and Keyboard mapping option yet in Options/Settings? Quote
