Recordings do not start after update
ddichiera
Hi there, I updated to the latest version of RS and now my recordings do not work.
I've tried re-entering them via the webinterface, but they just come up with a red button. If I chose a programme currently on air, and then go and force the button to green, RS starts up for a second (tray icon goes to red) then it stops again. I und up with a recording of about one second duration.
I've tried shutting off my anti-virus, I've even completely re-installed both DVBV and RS (clean installs with data sets wiped).
I have two servers, DTT and DSAT and updated both. Only the DSAT one has this problem. I've compared settings on both and can't see what's wrong.
Help?
Dominic
Ok, I seem to have fixed it, not quite sure why it went wrong in the first place.
I went into Timers via DVBV and put in an entry there and that seemed to sort it out. I don't normally use that method, as I usually only ever enter recordings via the webinterface.
BTW I noticed that after I put the timer entry in via DVBV, the webinterface timers page changed slightly. Now it has a header bar to separate different days, whereas it didn't before.
Dominic
