DVB Viewer stopped working
bfc_xxx
I have some problems with DVBViewer. It keeps crashing all the time.
I attach support.zip if someone can advise me.
regards
Start the DVBViewer via start menu > programs > DVBViewer > Support > DVBViewer Pro (Safe Mode).
Dose the DVBViewer crash than as well?
DVBViewer doesnt crash instantly.
After some minutes I see some glitches on the channels (the sound is NOT affected) and then it crashes.
I use x64 windows 7. This was happening also at x32 win7. It was working correctly only at windows XP.
Also DVBViewer never crashed until now at window mode, it crashes only at fullscreen.
Tray a different video decoder.
I tried but always the same.
Is there any way to find out what is causing the app to crash?
Is it my pc? the dvb card? the codecs? any plugin?
Is there any crash report to find out what is causing the crashes?
Does it crash with HD or SD material or both?
Thanx for the reply.
I just tested on HD and it is crashing also on HD.
Ok, when checking your support.zip i can see you are using an ATI Radeon HD 2900 pro with drivers from 2007. Im pretty sure these drivers are NOT supported on a Win7 64-bit OS. I suggest you to find drivers that are more up to date or simply change graphicscard :)
EDIT: The driver i'm referring to is the "ATI T200 Unified AVStream Driver". This one is for Windows ME / Windows 2000 / Windows NT / Windows XP / Windows 98 only.
Edited by majstang
I did a fresh install with windows 7 x32 and now it is working fine.
I dont know what was wrong though.
thanx for the answers :biggrin:
