trifon33 Posted May 2, 2011 Posted May 2, 2011 (edited) Hi, I have two devices in my HTPC: Hauppauge Nova T stick USB+ Technotrend TT DVB S2 3200 with CAM Viaccess SMIT. OS XP SP3 All DVB Devices driver updated. XP patch for DVB OK Visual C 2005 OK Audio filter: FFDShow audio compulsory because of DD+ for HD terrestrial chanels. Video filter Cyberlink SD/HD 8 or 9. Overlay Every thing works like a charm excepted I have some ramdom issue when chanel change from the Technotrend SAT to Terrestrial Nova T Stick. I have to go on several terrestrial chanels before the graph starts. Strantgly enough, it works better if I go to terrestrial HD chanels before come back to terrestrial SD chanel. The bar graph says it's OK but no sound, no picture. Click on "rebuild graph" does not make any good. As soon as I am on terrestrial chanels, no more issue when chanel change. This neither happens from Terrestrial to SAT Tested with and without direct tuning. USB device: open whole transponder checked. The issue is not depending upon DVBViewer version... UVD2 ATI HD 4670 is used. Nota: Same problem is reported by another USB terrestrial device users. Thanks for your help. support.zip Edited May 2, 2011 by trifon33 Quote
