ahyousoft Posted May 5, 2011 Posted May 5, 2011 Hello, Sorry for my bad english; I have problem tunning S2 transporders under DVBViewer, no signal detected i my previous post i didn't attach support.zip, it is attached here If you need any additionnel information just ask Best regards ------------------------------------------ HP Pavilion DV9600 laptop Windows XP SP3 DUO 2.10 GHz 3 go of RAM Skystar USB2 HD CI DVBViewer GEFORCE 8600X 512MO support.zip Quote
ahyousoft Posted May 5, 2011 Author Posted May 5, 2011 all dvb-s2 transponders in all satellites doesn't work Quote
Griga Posted May 6, 2011 Posted May 6, 2011 Try the latest DVBViewer version 4.8. You are still on 4.5. Quote
ahyousoft Posted May 6, 2011 Author Posted May 6, 2011 after installing 4.8 version still the same problem i also have a motor , should i remove it? by the way, i'm using a laptop, is it true that the usb should be powerful enough for hd channels? i have tried the demo version of progdvb but didn't work either... iam starting t othink that this is due to a malfunction in my box best regards. Quote
Griga Posted May 6, 2011 Posted May 6, 2011 Perform Options -> Hardware -> Detect Devices in DVBViewer 4.8. If it still doesn't work, please attach another support.zip so I can see how your device has been detected. Quote
