Tjod Posted May 10, 2011 Posted May 10, 2011 Check C:\Users\(USERNAME)\AppData\Local\VirtualStore\ for DVBViewer related folders and delete them all. An than disable and enable the UPnP Server in the settings.
SergeyKa Posted May 12, 2011 Author Posted May 12, 2011 Solved. UPNP Server started. I'm found what RS - "Server Option" write settings into the file "service.xml" C:\Users\(USERNAME)\AppData\Local\VirtualStore\, but RS use file "service.xml" from c:\ProgData folder... I'm stop service (RS), then replace file service.xml in c:\ProgData from C:\Users\ folder. Start service (RS) again. UPNP port (8889) listening OK.
