badtrip Posted May 11, 2011 Posted May 11, 2011 Hi everybody, As i'm changing my ISP, i need to change my mail adress because my ISP that i've been using since 1998 is very very expensive nowadays and there are alternatives... The billings are at the end of this month, i will be ending my contract and then i'll switch the ISP. As the company only lets their customers use their mail service. Mine will be deleted, and i wont be able to get any e-mails from DVBViewer team. And also change of email would mean, change of a username in DVBViewer PRO. And a credential change. Is it possible to change that parameter? If positive, please let me know to to go on the procedure.. Best Regards, Sabi RAZON Quote
Tjod Posted May 11, 2011 Posted May 11, 2011 And also change of email would mean, change of a username in DVBViewer PRO. And a credential change. Is it possible to change that parameter? No, it is not possible to change the credential. But it is not necessary. The eMail address in the credential is not used for sending eMails. Only if you did not have the "new" credentials, you should update them as long as you have assess to the eMal account (because it is easier than). http://www.DVBViewer.tv/forum/topic/42222-how-to-get-new-credentials/ Quote
badtrip Posted May 11, 2011 Author Posted May 11, 2011 (edited) Thanks for your reply @Tjod, As i understand, the username/mail adress that the credential has, is just a "string" and has nothing to do with a mail adress. I will be usiing the same username in the future and there will be no problems. As my recent mail adress would be gone, i still think i need to inform you my new mail adress, in case of a future password loss? I cannot find any for that i can change my e mail adress in the members section Note: Unfortunately i couldn't change my mail adress in the forum either Edited May 11, 2011 by badtrip Quote
